TS 6 pos chip
Old Feb 9, 2011 | 07:44 PM
97strokerHD's Avatar
Default TS 6 pos chip
Just installed a ts 6 pos chip on my 97 stroker but it just cranks and wont start. I cleaned the connections but idk. any suggestions
Old Feb 9, 2011 | 08:32 PM
joebob3093's Avatar
Moderator
is the chip tuned for a 97?
Old Feb 9, 2011 | 08:33 PM
OceanDiesel's Avatar
Does it have a Theft(no start) setting? Generic settings? Or custom tuned?
Old Feb 9, 2011 | 08:40 PM
Ya it has Theft. And ya its generic
Yes
No No it doesnt it just has. High idle, 50hp, 75hp, 100hp, 140hp, and stock
Last edited by 97strokerHD; Feb 9, 2011 at 08:40 PM. Reason: Automerged Doublepost
Old Feb 9, 2011 | 09:03 PM
Not trying to sound like an a**, but did you take it off, re-clean everything and try it again? Ensure it's on stock when starting it up? I'm looking at the TS guide I recieved with mine a few years back. While the chip is removed, start it to rule out/verify the chip is actually the problem.
Old Feb 9, 2011 | 09:09 PM
joebob3093's Avatar
Moderator
were the keys in the ignition when you installed the chip?
Old Feb 10, 2011 | 07:02 PM
Ya i cleaned it a few times. I got it from advanced diesel and they were supposed to send the supplies to clean it with the instructions and it didnt come with anything but i knew how to install it by learning from all you guys.
No i removed them and disconnected the batteries.
Last edited by 97strokerHD; Feb 10, 2011 at 07:02 PM. Reason: Automerged Doublepost
Old Feb 11, 2011 | 07:08 AM
ccarrier's Avatar
does the wait to start light come on?
pull the pcm again and make sure you didnt bend any pins.
remove the chip and see if it will start
Old Feb 13, 2011 | 12:13 PM
I got it going guys thanks for the info. Just cleaned the connections againg and i noticed that where the wires that connect the chip to with the **** wasnt all the way connected. My fault. thanks again everyone
cumminspwr11
Mar 27, 2015 11:40 PM
Dieselhead1052
Nov 26, 2014 05:43 PM
Dieselhead1052
Nov 26, 2014 05:42 PM
Paintrain64
Nov 25, 2014 06:29 PM
corey352
10
Nov 20, 2014 08:04 AM
