i need some help
Old Feb 9, 2011 | 09:52 AM
young gun's Avatar
Default i need some help
im lookin at buyin a 03 duramax with a 6speed manual. the guy said that oil leaks on top of the motor. the injectors were replaced about 40k miles ago and i assume that the leak started soon after. i was thinking that the valve cover gasket is leaking or something like that.. i was also thinking a turbo oil line or intake manifold gasket or something. just wantin some ideas if anyone could help out! i'd appreciate it!!!!
Old Feb 9, 2011 | 12:44 PM
2500HeavyDuty's Avatar
there aint much to fix up there on the top of the motor, i had an oil leak when i took my truck to get the injectors done at the dealer, there were a few loose bolts on the valve covers it fixed easily.
the only other place it could leak up top is from the turbo
Old Feb 9, 2011 | 03:31 PM
young gun's Avatar
so basically unless its a cracked block, which would be noticable, its nothing major and easy fix?? sweet thanks for the help!
