replace fog light assembly 01 2500HD
Old Jan 29, 2011 | 01:49 PM
mcanfield's Avatar
Question replace fog light assembly 01 2500HD
Has anyone replaced the fog light assembly, drivers side?
Do I need to remove the bumper to do this?
Any help would be appreciated.
Thanks
Old Jan 31, 2011 | 09:31 AM
02LB7DURAMAX's Avatar
I replaced both fogs on my 02, and no you do not need to remove the bumper. You need to lay on the ground and reach up on top of the fog assembly and there should be, I think 2 bolt you remove, and it should fall right out. Hope this helps you out.
Old Jan 31, 2011 | 05:02 PM
mcanfield's Avatar
Thanks for the reply, I finally replaced it, left a little skin under there.
Old Feb 1, 2011 | 01:35 AM
03Bduramax's Avatar
i had to replace mine on the drivers side on my 03 , i got small hands and they were a little cut up . Not worth it tho a week later i smoked a deer and took it out again!! hhahahahah
Old Feb 1, 2011 | 07:45 AM
dmaxtothemax's Avatar
I've got two new ones in the shed about to be put on... Did anyone have a bracket that blocked the 881 bulbs form fitting? i had to switch to a 880 bulb to make it work...
Old Feb 4, 2011 | 05:10 PM
cfarley0210's Avatar
i had to replace both of mine on my 02 it was a huge pain. i didnt have to remove the bumper but it probably would have been easier with it off
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
carid
Jan 6, 2015 06:28 AM
yams
Dec 7, 2014 12:51 PM
lawrek1
Wanted To Buy (WTB) - Used
Oct 2, 2014 12:08 PM
