Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
guages blink with use of subs need help!!!
Old Jan 27, 2011 | 10:27 PM
bschuldt0707's Avatar
Question guages blink with use of subs need help!!!
Hey i have a 760w amp in my truck with 12'' subs and when my subs start bumpin i guess you could you say my guages blink and at idle my rpm's drop also my voltage guage drops every time the subs hit should i install a bigger alternator or could i go with a bigger pully on the alternator anyone had this problem any help would be great thanks!
Old Jan 27, 2011 | 10:31 PM
RAW's Avatar
RAW
Neither the alternator, nor pulley. You need a capacitor. They store and release energy very quickly. They are installed in parallel with the power cable going to your amp. The closer to the amp the better.
Old Jan 27, 2011 | 10:35 PM
would that be why there is not a really fine point when it hits and how much does a decent one go for
Old Jan 27, 2011 | 10:37 PM
turbostang7's Avatar
that would be why! i got mine for $100 and it works great
wats a good brand
Old Jan 27, 2011 | 10:42 PM
i used rockford fosgate, seems to be a good one to me but i'm not too into car audio though, i googled it and looked at the reviews of them and got one that everyone said worked good
Old Jan 27, 2011 | 10:55 PM
RAW's Avatar
RAW
I ran a Fosgate, and a Stinger at different times. I didn't notice a difference between the two. Stinger cost less. I strongly suggest you get a 1 Farad Cap, don't let someone undersell you into a 0.5 Farad.
Old Jan 27, 2011 | 10:58 PM
sorry but wats the difference im new to subs
Old Jan 27, 2011 | 11:06 PM
RAW's Avatar
RAW
Farad rating is essentially how much energy it can hold. With your amp up to 15 feet away from it's power source, it takes a while for the power from the batteries to get to your amp. With a Cap close to your amp, it smooths out the power draw spikes. The alternator can't react quick enough to increase, then decrease it's output to satisfy the draw generated by the amp.
If you understand hydraulics, think of it as an accumulator.
Old Jan 27, 2011 | 11:13 PM
Up
alright thanks for the help i will stop at the pawn shop tomorrow
