Dead glow plug relay
Old Jan 22, 2011 | 01:37 PM
citroenRelay1997's Avatar
Default Dead glow plug relay
Hi peoples,
I urgently need a wiring diagram for my 1997 Citroen Relay 2.5D van.
I have cleaned all of the connections that I can find but still can't get voltage at the switch side of the glow plug relay. I have rigged a bypass switch for now but that will not pass the D.O.E. inspection which is due in March.
I have replaced the glow plugs, alternator, battery and glow plug relay - still no joy.
I am convinced that the problem is a bad wiring connection but without the wiring diagram I'm lost.
The wire which feeds the glow plugs appears to go under the engine to the alternator but because of tight engine space I cannot trace it.
All help will be appreciated.
Thanks in advance
Mark
Metz1234
Mar 3, 2016 10:20 PM
Texasthb
Mar 4, 2015 08:20 AM
Kooper
Jan 11, 2015 08:52 PM
norcal6.5
Dec 7, 2014 07:04 PM
7.3lfordguy
Oct 16, 2014 10:26 PM
