want more
Old Jan 21, 2011 | 08:15 PM
ChaseW's Avatar
Default want more
have a 1999 dodge cummins 3500 i have the quadzilla adrenilan ats manifold 4 inch turbo back is there anything i can do for more smoke will throw an ok haze but i want to be able to cover he road were people cant see got any ideas cant spend alot of money though t[/FONT]
Old Jan 21, 2011 | 08:20 PM
Red_Rattler's Avatar
High Tech Redneck
Plastic bag on the filter or put a cutout on the boost tube to dump the air. It'll smoke like a freight train then
Old Jan 21, 2011 | 08:29 PM
ChaseW's Avatar
wont that make me lose power though if i lose that sil i need the power because how much and how hevy i hall
Old Jan 21, 2011 | 08:39 PM
High Tech Redneck
The bag will for sure but if you put the valve on a cable you can control it then...
Old Jan 21, 2011 | 08:50 PM
ChaseW's Avatar
o ok my truck use to smoke alot till i rolled it now it wont somoke as much now i dont know why
Old Jan 21, 2011 | 08:55 PM
RAW's Avatar
RAW
Old Jan 21, 2011 | 09:00 PM
CSIPSD's Avatar
Remove the turbo... That seems to work.
You could also remove the compressor wheel and grind off every other blade.
Drill a few holes in the intercooler tubes...
You could remove the injectors and drill the nozzles out with a 1/8" drill bit.
Now if you want to make some power, rather then be a poser, ask that question... Because smoke is about the dumbest thing you can ask about.
Old Jan 21, 2011 | 10:12 PM
Rooster24v's Avatar
throw some 150 hp injectors in there.. with my setup i can black out most of an intersection.. dont ask how i know..
Old Jan 21, 2011 | 11:35 PM
dieselboy88's Avatar
As said above bud smoke billows when u have way more fuel than air. But if u want smoke without power loss then youl hafta throw a little money around. Just my opinion.
Old Jan 21, 2011 | 11:45 PM
01quadcab's Avatar
do us all a favor sell your truck and by a gasser this is what causes more laws to be made around smoke etc.
