Adjustable elbow... set screw worked out..
Old Jan 21, 2011 | 05:58 PM
1st_gen_puller's Avatar
Default Adjustable elbow... set screw worked out..
So as the title says i have an adjustable boost elbow from edge (came with comp box) and i usually run with it all the way in... My dads truck broke down and i had to use mine to do all his hauling so i backed it off for quicker spool and lower EGT's and now its gone... where do i gwt one??? or do i have to get a new elbow???
Old Jan 21, 2011 | 06:42 PM
turbostang7's Avatar
no i would take the elbow off and go to any hardware store, its just a simple set screw! will be like .50 to fix it nothing too bad. i would also put something ie teflon on there to give it some "bite"
Old Jan 21, 2011 | 06:45 PM
well i'd thought of that but then was like no... nothing can be that easy surely it'll be27 point double metric triple fine threaded high carbon stainless rustless steel.. lmao
Old Jan 21, 2011 | 06:48 PM
haha, nope, thats why i don't understand why people pay like $30 for these, all it does is block airflow, build one yourself and save the money for other mods
Old Jan 21, 2011 | 08:13 PM
RAW's Avatar
RAW
Plug the hose and save even more!
Old Jan 21, 2011 | 10:18 PM
EasternAggie's Avatar
You could but I dont think stock HX35's like 50 lbs of boost
Old Jan 21, 2011 | 10:25 PM
RAW's Avatar
RAW
I'm humping 57psi with my set up.
Old Jan 21, 2011 | 10:43 PM
57psi on a stock hx35!!!!! if thats the case you need to go buy a lottery ticket tonight because you are the luckiest person on here . the hx35 maxes out at about 32-35 psi anything beyond that is just superheated air and overspun turbo, both of which are bad and actually hurt power then help it, its easy to get caught up in boost pressure but thats not what actually makes the power its air flow, say you have an hx35 at 35 psi it moves x amount of air, a bigger turbo at 35 psi will move a lot more air at the same boost pressure thus making more power, make sence?
Old Jan 21, 2011 | 10:48 PM
RAW's Avatar
RAW
Maybe a closer gander at my sig will explain things.
Old Jan 21, 2011 | 10:51 PM
i see no sig
