fass makes p0089
Old Jan 21, 2011 | 12:25 PM
jdcanvas's Avatar
Default fass makes p0089
put fass on 01 duramax.with pump running get p0089.turn pump off runs fine with no code.Do I have to high of fule pressure ?Any help would be great
Old Jan 21, 2011 | 12:36 PM
Red_Rattler's Avatar
High Tech Redneck
Sounds like the pump is pushing too much fuel for commanded vs actual. Do you have a pressure gauge? did you buy it new or used? If used is it the right one for the truck or was this on a ford as an example?
Old Jan 21, 2011 | 06:55 PM
2500HeavyDuty's Avatar
10-12 psi is what you should have going to it.
what is your fuel pressure right now?
Old Jan 23, 2011 | 06:45 PM
jdcanvas's Avatar
the system is new for a duramax.just put guage and regulator on and turned it down to 5psi.seems to be fine so far.is 5psi to low?
Old Jan 24, 2011 | 02:05 PM
bftrain's Avatar
no. The stock system was running at a vacuum.
JoeyMiR
9
Feb 3, 2018 10:05 PM
2500HeavyDuty
Price Quote - Request A Price
Aug 11, 2015 04:31 PM
DODGEARMYGUY
Mar 3, 2015 11:40 AM
jdepuy618
For Sale
Dec 21, 2014 05:28 PM
CL-14
Oct 10, 2014 01:37 PM
