Air Bag Suspension...
Old Jan 18, 2011 | 09:23 AM
DanLowe's Avatar
Default Air Bag Suspension...
Ok, in the past, I have seen articles with a super soft ride 1-ton that utilizes a single leaf spring in the back to basically stabilize the axle, then an airbag for the actual load bearing suspension. Does anybody have a clue what manufacturer this might be, or if one of our vendors may handle anything like this? Thanks in advance-
Dan
Bump
Old Jan 19, 2011 | 12:00 PM
DanLowe's Avatar
so....nobody has seen this I take it?
Old Jan 21, 2011 | 08:04 AM
gwhammy's Avatar
I'm running a single airbag in the middle with self leveling valve. I cut all but the top two springs out of the back of the spring pack. This keeps spring wrap down with all the leafs in front. Rides like a half ton but will hold up any load I put on it. You can drive a 9000 lb. bobcat up with the bucket over the gooseneck and it will level right back up to ride height.
I made a frame out of two inch tubing on the rear end and made a drop bracket off of my gooseneck plate. My gooseneck plate is one inch thick plate and the air bag sets right under the ball. I've had it for about a year now with no problems. The only thing I need to change is a shorter bracket on the top so the airbag doesn't bottom out unloaded as bad.
I do have a belt driven on board air with a homemade 4X8 tube back bumper for a air tank.
Old Apr 3, 2011 | 05:30 PM
kyle davis's Avatar
ok not to steal ur post but i found this picture that is set up like a semi ( i will see if i can post it) and was curious about doing this to my truck also i already have a few big air bags and a welder
Old Apr 3, 2011 | 05:43 PM
Whit's Avatar
Site Mascot
yer not talkin bout Timbrens are ya??
Timbren Aeon Hollow Rubber Springs
Old Apr 3, 2011 | 07:18 PM
kyle davis's Avatar
no what i have in this picture on the hard drive is basically a tube 2" X 4" inch prolly 1/4" wall that replaces the springs completely and shortly after the axle it drops down for an air bag pad.. kinda like this http://www.stengelbros.com/RoadTamer.html like a road tamer setup gives u capacity and stops axle wrap
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
petew
Oct 25, 2014 09:29 PM
