tire size
Old Jan 17, 2011 | 02:34 PM
99powerstroke's Avatar
Default tire size
whats the biggest set of tires you can put on a 99 f350 no lift or leveling kit and 16 in stock rims i dont wanna rub at all
thanks
Old Jan 17, 2011 | 04:35 PM
CSIPSD's Avatar
No rub... 305-75 or 305-85...
Trim the bumper a bit and you could run 315-75...
Old Jan 17, 2011 | 07:58 PM
7.3 Cowboy's Avatar
MY 305 70 16 rubbed and have 3front leafs wich added a little bit of lift
Old Jan 17, 2011 | 08:10 PM
OceanDiesel's Avatar
I've got a 2.5" leveling and can fit 35's with no issues but am running 285/75's for snow. Once spring hits I'm getting another set of 305's to run, I like the extra clearance.
Old Jan 17, 2011 | 10:44 PM
i was looking at picking up a set of 35 by12.5 nitto mud grappler thats why i was asking thanks for the help
Old Jan 17, 2011 | 10:58 PM
CSIPSD's Avatar
Stock wheels they will rub on the springs and on the bumper. Trim the bumper and you might sneak by.
Old Jan 17, 2011 | 11:24 PM
nydiver's Avatar
I have to concur, my semi tires are I think like 36.3 inches and they rubbed the bumper and JUST cleared the rear inner fender. I had to add 3 thick washers per bumper bolt to move it out a smidge so the tires wouldn't rub when I turned. I would suggest you add just a leveling kit to make sure you get just a little more clearance, you still would want to move out the bumper a little or trim it. The leveling kit is pretty easy, it just adds 2 or 3 leaves to the pack, took us maybe 3 hours and that included replacing the arm bracket which SUCKED after I spun a "captured" bolt up in the frame.
Old Jan 18, 2011 | 03:44 PM
thanks
salty4life
Aug 20, 2015 10:46 AM
B737 Capt
Jun 9, 2015 06:34 AM
dallasca
28
May 26, 2015 12:58 AM
LB7yooper
Chevy/GMC Duramax 01-04 LB7
Mar 23, 2015 11:33 AM
LikeTheFabric
Ford Powerstroke 2011-Up 6.7L
Mar 10, 2015 01:18 PM
