which turbo?
which one of these two is better? i have a 96psd dp chip intake and straight exhaust. thanks chris
FORD TURBO 7.3 POWERSTROKE FAST SPOOL 100 TURBOCHARGER - eBay (item 110636283208 end time Jan-21-11 19:29:36 PST)
Powerstroke Turbo 1994-1997 FAST SPOOL .84 A/R Housing - eBay (item 330505138716 end time Feb-03-11 18:33:34 PST)
Better?
It depends on what you will do with the truck.
There are no pictures of the compressor wheel in the ad for the 1.0 A/R turbine turbocharger.
However, the compressor wheel in the .84 A/R housing is what you want. The drawback to the smaller turbine housing on that turbo is that you WILL feel a huge DECREASE in power at high RPM. It is far too restrictive to flow well at high RPM and will cost you power and will cause higher EGT. If you have an intercooler, it would work ok for spool-up times, but would still feel constipated at high RPM.
I would recommend going with the 1.0 housing turbocharger if you must.
Better?
Best Turbo...
Look here...
Beans Diesel Performance - 94-97 Power Stroke BDP Dominator 66 Turbo (Powered by CubeCart)
Look here...
yeah its all about cash.... im not really looking to go to big just need something that works and is pretty good.
is there any difference in mileage between them? i plan on buying a down pipe this week since it would be easier with the turbo out.
What is the problem with the .84??? I have a video clip at 130mph pulling up a moderate hill and @ 1300* egt and 28psi boost with a 4" ex. intake and chip otherwise stock and trust me i was pushing the hell out of it
The problem with the .84 housing is its too small, your drive pressures would be in the 70-80psi range...
I tore the turbo out of a 97 last week and replaced it due to a .84 A/R turbine housing. The insane drive pressure caused the thrust bushing and sleeve to disintegrate and ruin the compressor wheel and housing. Super Duty turbos suffer the same fate due to the smaller turbine housing.
Stock tires with 4.10 gears would put the RPM at about 4200. Not happening.
3.55 gears would be 3571 RPM. Feasible, but likely not enough power on stock sticks to overcome wind resistance.
[color=grey][size=-2]
