98.5-02 Cummins 24V 5.9L VP-44 Tech Talk Tech Articles for the 2nd Generation Cummins 24V 5.9L VP-44 Engines.
24V CTD Engine Specific Specs COOL STUFF !!!!!
Old Nov 23, 2007 | 11:49 PM
DB Admin's Avatar
Banned
Default 24V CTD Engine Specific Specs COOL STUFF !!!!!
Engine Type
In-Line 6 Cyl. Turbo Diesel
Bore & Stroke
102.0 X 120.0 mm
4.02 X 4.27 In.
Displacement
5.9 L
359 Cu. In.
Compression Ratio
245 HP 2002 CTD
17.0:1
235 HP 2002 CTD
16.3:1
Horsepower
A/T
235 @ 2700 RPM
M/T
245 @ 2700 RPM
Torque Rating
A/T
460 Ft Lbs @ 1600 RPM
M/T
505 Ft Lbs @ 1600 RPM
Lubrication System
Pressure Feed-Full Flow W/ Bypass Valve
Block
Cast Iron
Crank
Induction Hardened Forged Steel
Head
Cast Iron W/ Valve Seat Inserts
Combustion Chambers
High Swirl Bowl
Cam
Chilled Ductile Iron
Pistons
Cast Aluminum
Rods
Cross Rolled Micro Alloy
burndiesel
10
Feb 7, 2023 01:15 AM
rrough96
Feb 21, 2015 11:26 AM
