Truck almost dies then catches itself
Old Jan 16, 2011 | 12:45 PM
jessh's Avatar
Default Truck almost dies then catches itself
When driving down the road the truck acts like its going to die then it catches itself and stays running. It came up with codes PO603, PO344, PO470. Would those be from the Crank Position Sensor?
Old Jan 17, 2011 | 10:51 AM
CSIPSD's Avatar
https://www.dieselbombers.com/ford-p...ble-codes.html
P0603-Keep alive memory... Thats from clearing your codes... Nothing to worry about.
P0344- CMP sensor... There is a CPS code...
P0470- EBP sensor fail... Your EBP tube is plugged up or your sensor is plugged or unplugged... Not the cause of your issue, but should be fixed.
Sounds line you have a bad CPS. Have you had the recall done?
Old Jan 17, 2011 | 12:17 PM
jessh's Avatar
Nope I have the envelope on my center console guess Ill call and get it done. I was looking at getting one of the plugs that bypasses the EBP Sensor and then this summer putting in the non waste gated exhaust housing. Would you recommend that option?
Old Jan 17, 2011 | 04:31 PM
CSIPSD's Avatar
I would not. I would fix your EBP sensor and tube. It is used in tuning.
Old Jan 18, 2011 | 01:45 PM
jessh's Avatar
OK Thats good to know thanks.
Old Feb 1, 2011 | 03:22 PM
jessh's Avatar
Had the recall done and so far everything has been good.
redjello
Apr 21, 2015 12:35 PM
1969olds
9
Apr 18, 2015 02:59 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Strokin in wisco
Jan 23, 2015 12:28 AM
Oct 14, 2014 08:40 AM
