Air dog lift pump advice
Old Jan 16, 2011 | 11:32 AM
zbructo's Avatar
Default Air dog lift pump advice
I was wondering if i should go with a airdog 100 or 150 series with running stock settings. Also is there a good setting on the lift pump that i should run it at. I'm trying to just get my truck running good for now after a head gasket replacement and now replacing injectors after two went bad.
Old Jan 16, 2011 | 12:47 PM
TruePerformanceDiesel's Avatar
FormerVendor
If you don't plan on going crazy tuning the 100 will work just fine. If you do plan on going crazy with it I'd get the 150.
For settings don't higher then 12 Psi. I'd leave it at the preset 10 psi. if get surging when back out of the throttle turn in down a little.
Old Jan 20, 2011 | 08:24 PM
2500HeavyDuty's Avatar
id get the 150, cant have too much flow its all regulated anyway.
but 100 is ok for a daily, low power vehicle. my tuck makes around ~500 and i have a 150 and it holds about 5psi under WOT
Old Jan 20, 2011 | 09:09 PM
crzycummins's Avatar
id go with the 150...they are the same price if my memory serves me correctly. that way you will have room to upgrade if you decide to
Old Jan 21, 2011 | 05:57 PM
zbructo's Avatar
Thanks for the comments actually did go with the 150 and is running great.
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
dawnrogerl
Price Quote - Request A Price
Jan 29, 2015 01:03 AM
Anh Chà n
Jan 9, 2015 12:45 PM
veggyoilkid
Nov 10, 2014 12:39 PM
