Wicked Wheel Install
Old Nov 23, 2007 | 08:51 PM
britton02f250's Avatar
Default Wicked Wheel Install
is their anyone in Oklahoma that could take care of this i Had A GUY LINED UP BUT HE LEFT ME HANGING sorry about the caps. i had surgery wed. and now I'm not available to help like i hoped would happened.so if you can do this i could pay you or i have a heavy duty toolbox i could trade you. this isn't a cheap home depot Orlons. it is a very deep box maybe 3 inches from hitting the bed. please if you are willing tp do this please know what you are doing because this truck is my pride and joy
Old Nov 23, 2007 | 09:28 PM
LOGANSTANFORTH's Avatar
your wanting to put a wheel in a turbo?????? your post is kinda confusing....
Old Nov 23, 2007 | 09:50 PM
Whit's Avatar
Site Mascot
Courtisy of Joe at SDD
The commonly refered to, Wicked Wheel, Turbo Compressor wheel can be installed without removeing the turbo from the engine. It can be done with common hand tools and basic mechanical ability.
Here Ya Go:
Tools needed:
1/4" drive, ratchet.
1/4" drive, 12 point, 5/16 socket.
1/4" drive, 4" extension & 6" "wobbley" extension.
Phillips Screwdriver. (#6)
An 8 & 10mm socket.
5/8 box end wrench.
Procedure:
1. Remove ALL of the Intake tubes, exsposeing the turbo inlet.
2. Remove the 2 bolts from the CCV intake mount.
3. Move the CCV mount, exsposeing the 2 phillips screws. Remove the CCV filter from the valve cover. (watch for the O rings)
4. Loosen the "V" clamp that connects the turbo to the "Y" pipe.
5. Loosen The "V" clamp that connects the turbo to the down (exhaust) pipe.
6. Remove the 2 bolts that hold the Wastegate actuator to the turbo, move it up and back.
7. Remove all the bolts (5/16ths) from the turbo houseing. (you will need the 6" wobbley to remove the bottom back bolt, due to the valve cover) Split the turbo, exsposeing the stock turbo wheel.
8. Take a break.
9. With a screwdriver, wrapped with tape, insert it in the exhaust side of the turbo. Catch one of the vanes, with the 5/8ths wrench, remove the stock wheel (left to loosen)(use a clean rag, the vanes are razor sharp). Install the Wicked Wheel, Torgue to 10 inch pounds (or, real snug. it's tightening in it direction of rotation)
Reverse the dis-assembly procedure and yer dun.
HINTS: I loosen the bolts with the ratchet, then use a cordless screwdriver to back everything out. Same in re-assembly, then Tighten with the ratchet.
After the install, and after 4 or 5 warm-up cool-downs, check and re-tighten all turbo bolts. I use Red Loc-tite.
BIG HINT: Print these instructions, go out to yer truck/X, walk yerself thru them. Soak the "V" clamps the night before wit penatrateing oil or diesel.
Old Nov 24, 2007 | 06:40 AM
Old Dec 31, 2007 | 10:20 AM
Deputydog's Avatar
I also installed my WW with the turbo on the truck and had no problems at all..
Old Dec 31, 2007 | 03:18 PM
got it done tried to do it withn the turbo on but ended tahink it off couldnt get the bottom bolt that you had to use the 6inch wobbley on off other than that went pretty good thanks for the posts and help.
Old Dec 31, 2007 | 03:59 PM
Whit's Avatar
Site Mascot
so please tell us performance wise......woth it????????
Old Dec 31, 2007 | 06:26 PM
Blue01F250's Avatar
Duramax Virgin
Sweet bud!!! Glad you got it on -- I was gonna tell ya to come to the meet in Tulsa on the 19th and we'd do it there!
But come anyway!
and how do ya like it so far! Louder whistle sound good?
Old Jul 27, 2010 | 06:27 PM
coper's Avatar
T
he shaft is bent any ideas and can i just replace the shaft
Old Jul 27, 2010 | 08:31 PM
CSIPSD's Avatar
Holy old thread...LOL
Have to rebuilt the entire turbo at that point.
