Dodge Diesel Tech Articles All Years of Cummins Tech Talk
turbos
Old Feb 17, 2008 | 06:47 PM
DB Admin's Avatar
Banned
Default turbos
The PDR Twin Turbo systems are recommended for trucks that are running over 450hp in high performance street, racing and pulling applications. Our systems are ideal for high horsepower trucks that tow and high horsepower applications concerned with minimizing turbo lag. Or if you simply want your truck to have it all. For trucks under 450hp you should consider the PDR HX35 and HX40 turbos. For higher horsepower trucks that do little towing and don't need to spend the costs of a twin turbo setup, consider the B1 Series turbos.
PDR Twin Turbo systems are available in configurations for 89-93 1st gen, 94-02 2nd gen and 03-04 3rd gen Dodge RAM trucks. PDR Twin Turbo systems are available in 3 main turbo configurations for different horsepower levels and driver preferences. All turbos are custom built to PDR specifications, which may include modifications to the oiling of the turbo shaft, PDR's extreme heavy duty bearings, and zero balancing. The primary turbo exhaust housings are modified with larger wastegates and to allow the wastegate to work on all 6 cylinders.
Towing Twins
HX35
HT3B
50 psi
450HP - 550HP
Street Twins
HX40
HT3B
70 psi
550HP - 700HP
Racing Twins
S440
Big Brother
90 psi
700HP - 900HP
Note: There are multiple exhaust housing sizes for both the primary and secondary turbos which can be used to custom tailor each twin turbo system to individual customer needs.
Towing Twins - Ideal for higher HP trucks that tow. Excellent spoolup. Sacrifice upper end HP, for better spooling, lower smoke, and lower cruising temps with that heavy load.
Street Twins - Ideal balance between good spoolup and higher boost levels. Spools pretty well. Can be used for towing, yet still support higher HP trucks.
Racing Twins - Ideal for extreme HP trucks that want all out performance. Sacrifice some spoolup compared to street twins ( although still much better than a large single ), to gain all out performance for racing or pulling
The PDR Twin Turbo kits are sold as a complete kit including both turbos and exhaust housings, all plumbing, air intake system, oil return lines, clamps and mounting hardware.
PDR Twin Turbo kits can also be sold as an upgrade for those who already have a PDR turbo and/or an ATS manifold. Existing exhaust housings may need to be exchanged for the one designed for the twin turbo kit.
PDR recommends no more than 50psi without O-Ringing the head. Higher boost levels will require various combinations of O-Ring'd heads, stud kits, special head gaskets and our complete PDR intercooler boot kit.
The PDR Twin Turbo kits comes with a 5" downpipe that is long enough to run just past the transmission bell housing area. It is the customers responsibility to complete the exhaust system from here. PDR recommends a complete 5" exhaust for all high hp / high boost applications. For those needing an exhaust brake, the kit can be combined with a 5" remote mount exhaust brake from PacBrake ( not included ).
The PDR Twin Turbo systems use a large aFe air filter with 5" inlet. The intake for each system is custom designed to fit each style truck. Because of the 5" inlet, existing air intake systems such as an aFe Mega Cannon or Scotty2 will need to be replaced with the aFe filter that comes with our kit.
All PDR Twin Turbo systems allow the customer to keep the second battery. For 2nd gen trucks equipped with automatic transmissions, the heat exchanger down by the transmission bell housing will need to be removed. This will require the use of an aftermarket transmission cooler to keep tranny temps in line while towing with heavy loads. This is not included in the kit.
Buddha Power (www.buddhapower.net)
Buddha Power can supply custom turbocharger systems for everything from improved factory performance to all out competition. Our experience and "in house" testing has enabled us to develop the perfect turbochargers for any level of performance. We have the precise size turbo systems to meet any volume or boost levels needed.
Borg Warner (TurboDriven.com - BorgWarner Turbo Systems)
The S300G features a compressor wheel with extended-tip technology. This performance and durability feature helps the turbo boost harder without over-stressing the compressor wheel. With proper modifications°, the S300G replacement turbo can deliver the air to help the 5.9L engine produce 350 to 400 horsepower! The S300G will effectively replace the Holset HX35W and HX40W turbo applied to truck model years 1994 to 2002.
BD Power (Diesel Performance | BD Power)
Dodge Super "B" Single Turbo
These kits are designed for the Cummins 5.9L from 1994-2002 model year trucks with 75-200 additional or 300 to 425 RWHP. True Benefits are reduced smoke emissions ans well as lower exhaust gas temperatures. All exhaust, intake and oil adapters included.
A simple description of the operation of a turbo is to compare it to an air pump. The ultimate design is for the turbo to reach its peak boost pressure quickly and not create a lot of exhaust backpressure to drive the turbine wheel.
1994-1999 stock engines have the 12 sq cm w/g hsg that can be quite restrictive when the power is increased above 300 flywheel HP and results in high exhaust temperature. Changing to the 14 sq cm w/g turbine hsg # 1045920 or the 16-non/w/g hsg #1045910 will reduce temperature and improve engine power.
2001 automatic transmission equipped engines have a 9 or 10 sq cm hsg that is too restrictive for a high power increase (beyond the 300 hp) BD's new HX35 Turbo is better.
1994-04 Engines with 50-200 hp modifications work best with the Super B Single turbo kit. The kits come with the exhaust and intake adapters required to bolt into place. 2003 and 04 kits include an adapter so the turbo mount exhaust brake can bolt up; earlier models require a remote mount exhaust brake. Earlier year kits come with a 4" down pipe. 2003-04 Engines that have any more than a 100 hp increase will cause the stock turbo to over speed, surge and fail. The Super B Single is designed for 50-200 increased power and beyond that our twins respond quickly.
BD Super "B" Twin Turbo Kit
This big power kit is designed for engines with 150-350 HP above stock or 350-500 total RWHP. These compounded turbos respond like no other single! Superior bottom end response with compounded cool boost pressures result in the ultimate airflow for your engine. Dramatic reduction of exhaust gas temperatures and increases in power should be expected. Kit comes complete with all exhaust adapters, stainless steel air intake housings, poweder coated pipes, heat shields and oil adapters.
BD's Super B Twin turbo kit is designed for Dodge Rams with Cummins Diesels with fuel modifications that with the right amount of fuel and air they will develop 350-500 rear wheel Horsepower.
This engineered two stage compounded set of Air Werks S300 turbochargers meets the engines air requirement and keeps exhaust emissions very low with low exhaust temperatures. Turbo boost developed by the high pressure turbo provides quick low engine rpm response, this air charge is compounded by the low pressure turbo which has a broad compressor map for the high engine rpm. The high pressure turbo is the same one we use in the Super B single kit. You can progress from the single to the twins as your desire for more develops
Tests show that at 450 Rear wheel horse power exhaust temperatures pre-turbo of 1175 F were experienced and 51 Pounds of turbo boost was developed on a 2002 ISB Cummins. The exhaust smoke was level was only 3 out of 10. Oringing of the head is not a requirement at this pressure.
The kit is complete with a SS X Intake, exhaust and intake piping and oil drains, heat shields and the 03/04 application evens comes with a 3 piece pulse exhaust manifold to bolt on
If your engine fuel modifications are only 225-375 rear wheel horse power the new Super Single B BW-Air Werks turbo out performs and is less expensive than any turbo on the market. It just needs a new down pipe or adapter to install on your truck. See the Single listing on the web page for more details.
Jannetty Racing (Jannetty Racing Enterprises)
Super turbo: High rpm and extreme hp applications only. I.E. Tractor Pulls, Mud Bogs, Drag Race .
(Note: This is not a "street" turbo and will give up a lot of low rpm spool up for extra high rpm power)
Aug 7, 2015 12:40 AM
LadyyD
Chevy/GMC Duramax 2011 LML
10
Jun 1, 2015 05:30 PM
Dustin M
Mar 30, 2015 09:46 PM
250 gottiline
6.2L & 6.5L Performance
Nov 28, 2014 08:19 PM
offroad00
24
Oct 23, 2014 03:28 PM
