Dodge Diesel Tech Articles All Years of Cummins Tech Talk
torque converter install
Old Dec 1, 2009 | 02:16 PM
BC847's Avatar
Default torque converter install
In a nutshell:
- Remove the torque converter's bolts that attach it to the flex-plate.
- Remove the transmission fluid lines from the trans.
- Disconnect the shift/TV linkage.
- Disconnect the drive-shaft.
- Remove the rear mounting bolts.
- Remove the bell-housing bolts.
- Slide the thing back with the torque converter still in the bell-housing . . ..
To expose the flex-plate.
I figure your flex-plate is cracked/broken around and in those webs.
In this image, I've got a stock/OEM 1st gen flexplate nested in a later/newer flex-plate. You can see that the newer one is much thicker.
Wizbangdoodle
Ford Powerstroke 08-10 6.4L
Sep 26, 2015 02:47 PM
alysiamc
Jun 19, 2015 02:03 PM
cumminsbred01
Feb 17, 2015 12:26 PM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
Tmaxxrox97
10
Nov 10, 2014 10:37 PM
