ABS Lights And No Speedo
Old Nov 22, 2007 | 02:20 AM
spoolinaround's Avatar
Default ABS Lights And No Speedo
well I now this isint the most urgent thing in the world but I figured it would get the most exposure here and hopefully someone might have an answer before I get so fed up with this truck that I use it for target practice with my ar15
never the less I have changed the rear end speed sensor,the output speed sensor in the transmission, all new fuses and I still have the abs lights on and no speedo, I have to go to chicago saturday and I would really like to have a working speedo, and yes the gauge cluster is good because we swapped it in another truck and it worked fine.... like I sad above I am at my witts end with this thing and I am about ready to trade it in. suggestions?
Old Nov 22, 2007 | 12:30 PM
OneBadBia's Avatar
I'm a girl!
is your odometer working?
Old Nov 22, 2007 | 04:02 PM
no it isin't
Old Nov 22, 2007 | 05:01 PM
OneBadBia's Avatar
I'm a girl!
your gonna need a schematic or maybe some one can tell you which wires to check. Check power going to the module and ground coming out of the module. Its either a wiring issues or maybe the ABS module is toast.
Old Nov 22, 2007 | 05:06 PM
bow2no1's Avatar
check yer fuses.... i had the same issue a while ago. i don't remember exactly what the problem was but i'm thinking it was one of the fuses??
Old Nov 23, 2007 | 12:02 AM
LOGANSTANFORTH's Avatar
most likely a ground.
Old Nov 23, 2007 | 11:01 AM
Razutak's Avatar
Might want to check the wiring on that back speed sensor. Mine got all frayed and shorted out because of all the gravel roads and snow during the winters.
Old Nov 23, 2007 | 12:07 PM
dmaxjenn's Avatar
IT'S A GIRL!
dodge or chevy or ford?
id check your fuses..
Old Nov 23, 2007 | 01:05 PM
OneBadBia's Avatar
I'm a girl!
he sais he has all new fuses in the truck so im guessing he just went ahead and replaced all of them? Its more than likely a wiring issue.
Old Nov 23, 2007 | 01:21 PM
dmaxjenn's Avatar
IT'S A GIRL!
what kind of truck Bia , ?
