injectors
Old Jan 11, 2011 | 06:34 PM
farmboy01's Avatar
Default injectors
im looking for stage 1 injectors, which brand is good and does not cost an arm and leg
Old Jan 11, 2011 | 11:38 PM
Riffraff Performance's Avatar
FormerVendor
Are you looking for new or reman Stage 1? Also, are you planning on getting a custom tune on your edge or changing to a flip chip.
Old Jan 11, 2011 | 11:55 PM
DIESELMECH95's Avatar
What are stage 1 injectors?
Old Jan 12, 2011 | 01:17 AM
farmboy01's Avatar
i want to keep my edge, can you get custom tunes on them. reman would be fine if they dont go out in a year. and to answer the question stage 1 add about 50-75 hp to your truck over stock. can you do stage 2 with out other mods than just a chip or programer?
Old Jan 12, 2011 | 11:22 AM
FormerVendor
If you want to keep your Edge you will need to see if someone like PHP can flash it for you. Stage 1 are 160cc/ Stock nozzle and Stage 2 are 160cc/100% nozzle. They carry an 18 month warranty as well. Alot of us prefer a flip chip so that you can switch a tune on the roll as well as have more to choose from, just something to consider.
Riffraff Diesel: Full Force Diesel / Casserly
Riffraff Diesel: DP Tuner
Old Jan 12, 2011 | 11:49 AM
Lange503's Avatar
PHP has good tunes thats who i run, just call them and let them know what you want and they'll get you set up on your edge, and full force has an 18 month warranty like said above, and they are one of the best 7.3 injector builders around
Old Jan 12, 2011 | 12:32 PM
CSIPSD's Avatar
Yes, if you want to keep the Edge you have two choices, send it to PHP to have single shot tuning put on it...
or...
Get some split shot stage 2's built....
I would NOT go with split shot anything.
Old Jan 12, 2011 | 05:07 PM
farmboy01's Avatar
thanks for the info, what is the difference between split shot and single shot. thanks for the help
Old Jan 12, 2011 | 05:29 PM
CSIPSD's Avatar
https://www.dieselbombers.com/ford-p...ease-read.html
Look here...
Old Jan 12, 2011 | 06:01 PM
95powersmoker's Avatar
I have Full Force stage 1's and I'm happy with them...
