To get a fuel pressure gauge, or not to get a fuel pressure gauge?
Old Jan 10, 2011 | 07:10 PM
Mrfatsac789's Avatar
Default To get a fuel pressure gauge, or not to get a fuel pressure gauge?
Hey, im going to get a set of isspro gauges but i was tryin to decide if i should get a fuel pressure gauge or not. My truck is pretty much stock right now so im not to worried about fuel pressure but later on when i get more upgrades im thinking i might need it. I know hat i dont need a tranny temp gauges because i have a 6 speed manual so i dont really hav to worry about that. I just wanted to get a little help feom you guys. I have the choice to get it or not cuz im for sure going to get pyro and boost.
Old Jan 10, 2011 | 07:24 PM
mishkaya's Avatar
A fuel pressure gauge on a VP powered truck is an absolute must! Whether the truck is stock or not makes no difference! A fuel pressure gauge should be your very first BOMB!!!
Old Jan 11, 2011 | 10:34 AM
leorn's Avatar
Listen to this guy. It is the stock lift pumps that fail most often. Get your gauge. Also I'm of the opinion that you can never have too many gauges. It wouldn't hurt to have a tranny gauge, even though the manuals are not quite as prone to failure in stock form, a gauge may give you a chance to save it someday. I'm also the type that wouldn't mind a gauge for my rear diff.
Old Jan 11, 2011 | 12:38 PM
RAW's Avatar
RAW
Be a shame to see a $1000+ bill for a VP44 because one didn't put a fuel pressure gauge in. Stock or highly modified, the injection pump can fail from poor fuel supply.
Id get Boost, Pyro and Fuel Pressure.
Old Jan 11, 2011 | 12:58 PM
Farmboy 2.0's Avatar
Yep fuel pressure gauge is a absolute must on these VP trucks. Spend the money on the gauge now instead of $1000 later on the VP. And the combo Luke posted up is the best route to go. And also if you have a auto get a trans temp gauge at some point down the road. But get the boost, pyro, and fuel pressure first
Old Jan 11, 2011 | 11:20 PM
Russ Roth's Avatar
Heck no ya don't need one. Just pay to have it towed to your mechanic and then pay him to install another IP for ya. One of the most important things you can do for your rig, but what do I know????? Or these other guys?
RR
Old Jan 12, 2011 | 12:06 PM
dodge bomber's Avatar
i got a fuel pressure gauge and the fuel isolator is telling me to put anti freeze in it they talking about the gauge side? they dont say much after it but put the 50/50 mixture antifreeze in it? i would thin k gauge side bc you dont want that in the fuel is the gauge sapposed to work like that?
Old Jan 12, 2011 | 12:10 PM
If its mechanical yes. You want the antifreeze on the gauge side to measure the pressure otherwise you would be running fuel into the cab.
Old Jan 12, 2011 | 12:30 PM
now i just fill it up in the isolator not the whole line up into the gauge?
scott i believe you helped me but i just recently ordered parts from aligator performance and i was extremly happy with your service that was given to me thank you
Last edited by dodge bomber; Jan 12, 2011 at 12:30 PM. Reason: Automerged Doublepost
huntman7
Sep 4, 2015 04:49 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
