EJWA Wiring Harness
Old Jan 7, 2011 | 10:22 PM
dieselboy88's Avatar
Default EJWA Wiring Harness
Alright I got my chip in and it works great! but I don't have a couple of sensors (fuel pressure,Pyro, and transfer temp.) Might anyone have a tranny temp sensor. IV got a Pyro gauge and my buddies got the fuel pressure sensor still on his truck all I gotta do is swap out with him. But my main question is what is the boost read from cause I thought it was read from the map sensor but its showing that I Have zero boost. Any thoughts on why its not working? Thanks in advance.
Old Jan 7, 2011 | 10:45 PM
Default re: EJWA Wiring Harness
New or Used EJWA?
Luke
Old Jan 7, 2011 | 10:48 PM
Used chip brand new harness. I sent the old one in cause it was for an 01 and mines a 99.
Old Jan 7, 2011 | 11:58 PM
RAW's Avatar
RAW
There should be a "Y" connector in the harness. One to the MAP sensor, and the other to the MAP plug on the engine harness.
Old Jan 8, 2011 | 06:26 AM
Yea that was the first thing I connected RAW.
Old Jan 8, 2011 | 12:32 PM
RAW's Avatar
RAW
And still no boost on the Attitude, eh? If you or a buddy has a scanner, throw it on to see if the ECM is measuring any boost. If it is, there is a issue with the Edge system. If not, it could be a bad sensor. Should throw a code though.
Old Jan 8, 2011 | 01:24 PM
jake 94's Avatar
You need to get a lift pump proto but my edge does the same thing and ii sent it in they said they fixed it but it still doesn't work so I just run a boost fooler in place of it
Old Jan 8, 2011 | 01:54 PM
Wel ill ask the guy i got it from if it read it then but iv got a boost gauge so its not a great big issue to me. As for the lift pump i know. Its never gettin past level two till i get a better one for it.
Old Jan 8, 2011 | 04:04 PM
RAW's Avatar
RAW
If the Edge doesn't read boost it won't fuel properly. Its not like each level puts x amount of fuel in. It changes its fueling dependent on boost, amd other parameters.
Old Jan 8, 2011 | 07:54 PM
Well once my truck decides to start ima go get the fuel pressure sensor from my buddy but i cant even get the ______ thing started. Either i have water in my fuel or somehow the injectorpump lost prime.
