Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Used motor oil
Old Jan 7, 2011 | 10:10 AM
cummins1997's Avatar
Default Used motor oil
im getting ready to start running used motor oil but i have a few questions before i do so.
What would be the max % of used oil i could run?
would filtering to 2 micron be good enough?
Old Jan 10, 2011 | 08:58 AM
i did some more looking and found the answers to my questions
Old Jan 14, 2011 | 10:14 AM
Niteprowler's Avatar
What did you find out?
Old Jan 18, 2011 | 08:16 AM
Found that some people run up to 90% oil in the summer months, and filtering down to 2m should be good enough if it is filter several times.
Old Jan 18, 2011 | 10:35 AM
GuyWithA24Valve's Avatar
I wouldn't run used motor oil or tranny fluid in these newer diesels. In the older ones I wouldn't be afraid to run used motor oil in the tank.
Old Jan 18, 2011 | 11:50 AM
Deezel Stink3r's Avatar
Let me ask you a simple question. Why do you have a two micron limit? It is known by fact that particles around 1 micron do the most harm.
This size rips out other particles and is called the Avalanche effect. You will find this information from the Mann+ Hummel filter company.
By the way: 2 micron is also the measuring limit. You get difficulties to measure smaller than two microns.
Do a search and inform yourself about tolerances in an IP or Injector. You will be amazed how tight they are.
Old Jan 19, 2011 | 07:01 AM
Thanks for the info, i have a supply of 2m filters is why i asked about it. also im running this in the 12 valve
Old Jan 26, 2011 | 09:45 AM
veggyoilkid's Avatar
Default motor oil in fuel
I have not run motor oil in my fuel.
But a friend of mine has been doing it for 2 years now in his 96 12v cummins. He runs a 50/50 mix. He has not had any issues other than the smell of exhaust is not pleasant. I do not know details about his filtering system.
My brother has also run a small amoount in his 92 on occasion.
Old Jan 31, 2011 | 09:11 AM
thanks for all the info guys i bought some 1m filters for the final stage
Old Jan 31, 2011 | 01:40 PM
Default update
Spoke with my friend Sunday who runs the motor oil. He said #1 make sure you give your oil a chance to settle out. This will eliminate most of the problems he has had. The raw motor oil should settle in a tank, then draw the best off the top portion to use for your mix.
Good luck...
Let us know if you have good or bad results....
