Coolant leak????
Old Jan 6, 2011 | 07:11 PM
Back-in-Black's Avatar
Default Coolant leak????
2002, LB7.
Very slight coolant leak. When pressurized, you can see a small amount of coolant drip off the oil filter.
Anyone got a clue where this is coming from??
Old Jan 6, 2011 | 07:24 PM
mcsd913's Avatar
I have an 02 and my coolant leaks at the reservoir.
Old Jan 7, 2011 | 11:45 PM
brettdfny19's Avatar
could be from a hose with a wear spot or the water pump possibly...
Old Jan 12, 2011 | 01:38 PM
cstlb7's Avatar
heads maybe
Old Jan 19, 2011 | 08:26 PM
dieselgearhead's Avatar
Or it could be from the cross over built into the bellhousing. There are 2 plates bolted back there on the top slants, one goes to the oil filter housing and the other is blocked off. Had a coolant leak on mine and it ended up being a broken bell housing
Old Jan 22, 2011 | 06:19 PM
Some good places to look. Thanks for the replies. I know it's not the water pump because that's what I thought it was and why I pressurized it. It's coming from somewhere in the rear of the motor and it's just barely dripping when under pressure.
IHdude
Jul 12, 2015 11:14 PM
throttleup22
May 2, 2015 02:04 PM
Mike0885
Feb 28, 2015 03:16 PM
merdth6
Nov 20, 2014 08:01 PM
dieseldummy
6.2L & 6.5L Performance
Oct 1, 2014 07:51 AM
