VW Diesels Discussion of all things Volkswagen Diesel - TDI, Bug , Touareg , Jetta , Golf , Passat
serpentine belt
Old Jan 5, 2011 | 05:45 PM
FastCR's Avatar
Default serpentine belt
Am I missing something on changing the belt on my 02? After an hour and a half I was bruised and bleeding with a wrench stuck in the wall and no closer to having the new one in. It seems that NO wrench fits the bolt on the tensioner correctly. 16 doesn't go on all the way, 17 is too lose. I made a diagram for the routing before i took the old one off, but you can't see a friggen thing, maybe I'm routing it wrong? Does anyone have a diagram?
I totally lost my s*** at this point and I'm just cold and angry. There must be a trick to this.
Old Jan 5, 2011 | 07:17 PM
wildbill's Avatar
If a 16 was too small, it's gonna be a 5/8 or an 11/16.
Old Jan 5, 2011 | 07:34 PM
FastCR's Avatar
tried both. found the manual page, its supposed to be 16. its just a crappy bolt.
Old Jan 5, 2011 | 07:55 PM
wildbill's Avatar
Vice-grips are your friend also.
Old Jan 5, 2011 | 09:50 PM
FastCR's Avatar
yeah man I tried that route. theres only about an inch between the body and this effin bolt though, cant even get them in there and clamped. Can't even get a socket on it much less a socket and a ratchet. Looks like tomorrow I'll be looking for someone with a gear wrench serp belt tool with a lifetime warrenty i can force 16mm onto the bolt. Gonna jack it up and try it from the bottom too, although I'm not sure I'll do any better.
Old Jan 7, 2011 | 12:55 PM
85_305's Avatar
Being Evaluated
Why the hell was my last post deleted????????
Often times going thru the bottom is the BEST way to work on these cars. I can swap the turbo outta my car going thru the bottom in 3 hours. Going thru just the top it takes a good 5-6hrs.
Ironmanqb
Apr 4, 2015 10:27 PM
denpenn
Feb 11, 2015 11:29 PM
mnbf48
Jan 19, 2015 09:20 PM
jdcarter
Nov 29, 2014 11:31 AM
Floydfan38
Sep 28, 2014 06:21 PM
