7.3 engine 1994
Old Dec 28, 2010 | 09:30 PM
fast4turbo's Avatar
Default 7.3 engine 1994
so im looking at a 1994 f 450 with a 7.3, 5 spd. is this a power stroke, or just a 7.3 ? any good? i drive g.m. and know nothing about this one.
thanks!
Old Dec 29, 2010 | 12:07 AM
95-SimpsonOBS's Avatar
if its a powerstroke itll have the powerstroke decal on the side, if it doesnt that have that itll say DIESEL on it, that means its the IDI international. i know nothing about the IDIs but i was looking at buying one a year back that had 320,000 miles on it and was still running strong.
Old Dec 29, 2010 | 09:42 PM
95powersmoker's Avatar
Not true, Some 94.5 powerstrokes had the "turbo Diesel" under the badge. Check to see if the oil filler tube is in the front of the engine or on the valve cover, If in the front, its an IDI. Post up a pic and i could tell you which one it is.
Old Dec 29, 2010 | 10:18 PM
when did ford start putting the powerstroke decal on? thanks for the correction. good info to know
Old Dec 29, 2010 | 10:41 PM
CSIPSD's Avatar
Its on both the 94.5 models... I think they just started using them until they run out.
Old Dec 29, 2010 | 11:04 PM
bobcat67's Avatar
I know a guy with a 94 and it has turbo diesel on the side and is definitely a powerstroke, it should be pretty easy to tell by looking under the hood, they usually say something about direct injection on em if they're powerstrokes
Old Dec 30, 2010 | 06:41 PM
Mutley's Avatar
Mine's for sure a powerstroke and it says Turbo Diesel under the badging on the side. The oil dipstick is at the middle of the passenger side of the engine. They only came with 5 speeds during that model run that I know of. Good engines.
Old Dec 30, 2010 | 07:24 PM
fast4turbo's Avatar
thanks for the help!
if the engine is not a powerstroke, than it is idi? did they still have a turbo?
i need some power as this is a rollback. but my experience with idi diesels, they are not the best choice for hauling a load i will look at it next week.
Old Dec 30, 2010 | 11:55 PM
bobcat67's Avatar
idi's kinda suck and anyone that tells you differently is in denial
Old Dec 31, 2010 | 06:36 AM
Mutley's Avatar
Yes, there were turbos on the IDI as well which I suppose could be confusing. The direct injection gives it away however.
