P1211 woes
Old Dec 27, 2010 | 01:43 PM
twinboys's Avatar
Default P1211 woes
About a month ago, my 97 began having power issues. When accelerating, the truck would fall on it's face, set a 1211 code, then I could feel the truck revert to a pre-set icp signal. I would clear the code while driving and it would just happen again. This went on for a few weeks, then I put in my spare IPR valve. It did not make a difference. A day later, it SUDDENLY cleared up 100%. Now it started doing it again. When I think back, I remember this happening years ago on my 96, and I never figured it out.
Old Dec 30, 2010 | 12:55 AM
twinboys's Avatar
Has this happened to anyone else? Anyone care to speculate?
Old Dec 30, 2010 | 09:19 AM
CSIPSD's Avatar
Possable injector issue, possable ICP sensor issue... Need to get a scanner and watch it while driving.
Old Jan 20, 2011 | 10:03 PM
twinboys's Avatar
Assuming a problem with an injector and assuming o-rings are good because oil level has remained constant after @ 1000 miles, What should I look for in the absence of a scan tool? Would it/could it be a broken intensifier spring? Does this happen? If this was the case, would the exhausted oil be flowing from the injector rather than pulsing?
By the way, I have not looked yet to see if this is happening.
Old Feb 4, 2011 | 01:35 PM
twinboys's Avatar
Cleaned the IPR valve and fixed it.
I had some piston damage that I decided to live with from a screw getting sucked in. (had to replace a head). Since each piece of debris (aluminum) either goes to the engine filter and is removed OR goes directly to the HPOP, my HPOP system was acting as a filter for the larger pieces. The HPOP oil reservoir was extremely contaminated!
Old Feb 4, 2011 | 04:28 PM
95powersmoker's Avatar
HPOP oil was contaminated? What do you mean by that?
Jladanyi
Jul 4, 2015 02:43 PM
JFreeman510
Jul 2, 2015 02:18 AM
Da Bomb
Diesel Engine Conversions
Oct 6, 2014 09:18 PM
