EBPV not closing,,,
Old Dec 21, 2010 | 05:01 PM
99stackedpowerstroke's Avatar
Default EBPV not closing,,,
well i hooked up my EBPV to a toggle switch to use it as a break, i do have power through the wires and plug, i have hot and ground on plug, it doesn't close or click or nothing when i send power to it, with it running or not, any ideas guys??? thanks in advance
Old Dec 21, 2010 | 06:45 PM
PHPDiesel's Avatar
Sponsor
That's what I get when I don't look up the wiring diagram first before I open my pie-hole.
If you've already read the previous post, disregard that....I was WAY wrong.
Old Dec 21, 2010 | 06:47 PM
i cut the (yellow with red?) i did not cut the black and white wire, and wired it to a switch, i do have a power and a ground, i used a test light to test both sides,
haha its alright
Last edited by 99stackedpowerstroke; Dec 21, 2010 at 06:47 PM. Reason: Automerged Doublepost
Old Dec 21, 2010 | 07:00 PM
PHPDiesel's Avatar
Sponsor
Wiring diagram says gray/red for PCM side signal (high side control ) wire.
Old Dec 21, 2010 | 07:06 PM
ya gray/red that's why i had the question mark haha, so what could my problem be? if i try and pull the shaft coming from waste gate i can get it to move maybe 1/8 inch then it slides back into waste gate
Old Dec 21, 2010 | 08:47 PM
Kyle_KleinSS's Avatar
Yea its just the red/grey wire thats at bottom of turbo. Cut and put your switch on the side going to the sensor and thats it.
Old Dec 21, 2010 | 09:16 PM
ya i did that and nothing happens, it doesnt close no click, will it only close with it running and power sent to it, im trying to find out why it doesnt close when i send power to it,
Old Dec 22, 2010 | 11:30 AM
PHPDiesel's Avatar
Sponsor
You do realize that it is simply a valve that allows oil pressure to push against a piston, right?
It's NOT going to do anything without the engine running and supplying engine oil pressure to it.
You're not working with the wastegate here either (the rod on top of the turbocharger). You're working with the one near the downpipe on the bottom of the turbocharger underneath the turbine housing.
Old Dec 22, 2010 | 11:39 AM
no sir i didn't, thats what im trying to figure out, so it works that way even with the pcm unhooked?
Old Dec 22, 2010 | 11:44 AM
PHPDiesel's Avatar
Sponsor
Yep. Without the engine running, there is no oil pressure to activate the exhaust backpressure valve in the turbo pedestal.
The engine won't run without the PCM so there won't be any oil pressure to activate the EBPV. You won't hear anything in the pedestal though just by switching power to it.
