suction sound when turbo builds boost
Old Dec 21, 2010 | 09:52 AM
01_dmax's Avatar
Default suction sound when turbo builds boost
Every time i get into it are climb a hill i get this lound suction noise and the only time it does
it is when the turbo is building boost any suggestions why this happens, are how to fix
it.
Old Dec 21, 2010 | 04:46 PM
BriteWhiteRam's Avatar
can you give us any more info??
Old Dec 22, 2010 | 07:02 AM
Rttoys's Avatar
Sounds like you might have a boost leak. It might sound like a suction noise, but it's probably a pressure noise. The most common for this leakage on LB7's is on the dr boost tube, down low by the gear box. The ps hose that goes to the gear box will rub on the boost tube and create a hole. You can patch it with JB Weld, then add some padding so it won't happen again. I'll try to find some pictures of when I've done a few here at work.
Old Dec 22, 2010 | 02:42 PM
01_dmax's Avatar
Thanks for the info, i will look at it and find out. Also i am not building the boost i should be building.
Old Dec 22, 2010 | 02:43 PM
prison's Avatar
that would definitely verify a boost leak
Old Dec 22, 2010 | 03:24 PM
crzycummins's Avatar
yes you have a boost leak somewhere
Old Dec 23, 2010 | 10:21 AM
Rttoys's Avatar
You can read this thread to get a better idea of where to look: Thanks Diesel Place!!! - Diesel Place
Old Jan 3, 2011 | 03:11 PM
01_dmax's Avatar
Thanks for the help. My truck is running good once agian.
mpmcbride42
Apr 7, 2015 08:28 PM
n2brk
Feb 21, 2015 09:05 AM
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
GreenDieselF
Oct 20, 2014 02:05 PM
