Smoke
Old Dec 20, 2010 | 05:11 PM
cody73's Avatar
Default Smoke
I just bought another 7.3 and its pullin some stuff on me. When I start it its not smoking or surging or anything but after it runs about 3-4 minutes it will start smoking blue, but the tricky part is that the blue smoke does not smell like oil at all it is clearly fuel smoke by scent it burns your nose and eyes. Now I think it is bad injector o-rings because of the blue smoke and fuel scent, but I want to know what yall think before I dig into it possibly chasing the wrong thing. the truck is a stock 96 with 195000 on it and injectors appear to be pretty sound because this truck will **** *** its just smoking.
Old Dec 21, 2010 | 02:51 PM
powerstroke312's Avatar
coulif its fuel u could have a cracked injector cup or a nozzle could be getting stuck
Old Dec 21, 2010 | 06:44 PM
cody73's Avatar
But wouldnt I be experiencing at least a little power loss and a miss? I also forgot too mention above that the smoke will totally clear after about 5 miles of driving and wont come back unless I idle for long periods of time or shut it down for an hour or two and restart.
Old Dec 22, 2010 | 02:46 PM
ya true it would be missin if it was an injector cup... do u have a lotof blow by?
Old Dec 23, 2010 | 11:26 AM
cody73's Avatar
Yeah quite a bit of blow by thats another reason I am thinkin injector o-rings. I think they are letting some compression escape around the injectors causing blow by because the piston rings are fine. And the motor is tight.
Old Jan 28, 2011 | 01:12 AM
sorry toook so long to reply ...are you haven any water loss?
Old Jan 28, 2011 | 03:17 PM
RattleBomb7.3's Avatar
if its got blowby wont it smoke 24/7??
Old Jan 29, 2011 | 01:04 AM
all motors have nblow by just depends how much
Old Jan 29, 2011 | 11:39 AM
CSIPSD's Avatar
Blow by is not caused by injector O rings.
Run a cylinder contrubution test, buzz test, compression test and leak down test.
That will tell you all you need to know.
I would bet you have some injector issues, but I doubt its the external O rings, more then likely some internal issues with the injectors with 200k.
Old Jan 29, 2011 | 12:48 PM
my truck has 205+k and it smokes pretty hard when its cold but as soon as it warms up there is hardly even a haze at WOT.
