Fuel pressure at Shrader valve
My pickup died and CEL came on the pressure at shrader valve is jumping from 40 to 80 psi instead of the 75 it used to sit around at idle. Wiggled wires and wont change or die cleared code P1211 ICP above below desired. Unplugged ICP threw code and ran slightly rougher. Fuel is coming from front tank gonna fill rear and see if that matters.
Anyone else had this issue, maybe clogged fuel straw in tank or something.
Thanks
Thanks
Died about four times while downshifting from third to second yesterday. P1211 ICP and boost code came up every time. Have a scanner hooked up but couldn't see pressures change enough to kill it. what should pressures of ICP and IPR be? I am using determinator scanner.
Just replace it. If that wasn't the problem, you will have a spare. You should keep a spare in the glove box anyway.
Do you have good fresh oil it with the proper rating? Any recent repairs involving silicone?
Make sure your batteries have full charge. You need atleast 100 rpm for computer to allow injection. Then watch your rpm gauge as you crank, If it shows zero, then your cps went completely bad. I'd still replace it regardless.
RatsMC
May 4, 2015 05:25 PM
