running on 3
Old Dec 9, 2010 | 09:09 AM
ray prewitt's Avatar
Default running on 3
i have an 06 cummins 2500 4x4 was traveling down interstate and truck started running rough. checked codes and found fuel delivery and group a circuit open. changed valve cover gasket and fuel filter still same problem. 1 2 & 3 injectors not working any help
Old Dec 9, 2010 | 03:28 PM
Whit's Avatar
Site Mascot
common rail people please chime in
Old Dec 9, 2010 | 06:53 PM
nodd89's Avatar
actaul code numbers would help
Old Dec 9, 2010 | 08:56 PM
Default running on
Codes p0148 and p2146. Ohmed injectors all were 1 ohm except number 2 128.46. !_( dealer did injector kill and said 1 2 3. Made no difference on running. 4 5 6 made a difference when killed
Old Dec 12, 2010 | 12:13 AM
cummin_un_glued's Avatar
FormerVendor
replace #2 injector....starting to see this problem more latly...seen 3 trucks (4 injectors) with the same problem in the last month...a bad injector kills all 3 on that circuit....you can clear the code and it will run right for a couple min then drop that whole circuit again
Old Dec 16, 2010 | 09:22 PM
nodd89's Avatar
sorr y i never got around to opening my alldata up to look he codes up....did u figure it out yet or do u still need assistance
Old Dec 17, 2010 | 09:17 AM
Default runing on 3
Yea got it fixed. Dealer couldn't find it. Found #2 injector bad.
ssmith.77
Nov 25, 2018 06:56 AM
ROCKITV8
Jun 17, 2015 08:38 AM
carid
Diesel Bombers Sponsors
Apr 6, 2015 08:43 AM
CumminsAtYa
Mar 17, 2015 09:23 AM
carid
Jan 12, 2015 04:32 AM
