Rough Idle at Stop Lights
Old Dec 8, 2010 | 09:52 AM
hyundaibus's Avatar
Question Rough Idle at Stop Lights
My 2004 duramax LLY is idling rough at stop lights. It does that when it's on drive, fully warmed up, and blows out a lot of white smoke with a strong exhaust smell. There is NO check engine light on. When idling from cold start, it's fine. Also smoke goes away when: placed on neutral or park and idle smooths out. Smoke also goes away when driving.
Old Dec 8, 2010 | 09:15 PM
Dude_57's Avatar
Check the idle setting??
Old Dec 8, 2010 | 09:21 PM
jbrown1132's Avatar
sounds like injector. get the injector rates checked.
Old Dec 8, 2010 | 10:18 PM
cummin_un_glued's Avatar
FormerVendor
yep what he said, really sounds like leaking injector(s)
Old Dec 14, 2010 | 03:37 PM
hyundaibus's Avatar
Question Still shaking and smoking
Just changed fuel filter, acceleration improved, but still shakes at idle with fully warmed up blowing out a lot of white smoke, only when in gear (drive or reverse). When it was 50 degrees the other day, it did not shake and smoke. It seems to occur when cold outside (ie below 50 F).
Old Dec 18, 2010 | 04:45 AM
Whitecummins's Avatar
Could be a torque converter?
Old Dec 19, 2010 | 03:46 AM
FormerVendor
does it only do it while the engine is cold? if so then it sounds like the glow plug relay a duramax actually cycles the glow plugs on and off while the eingine is running until it warms up so that would be possible....if it does it all the time then it still sounds like leaking injectors so you still need to have the balance rates checked on them....at idle is the only time that the engine is in the balance mode, as soon as you touch the throttle the balancing shuts off
crazycooter
Sep 22, 2015 08:43 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
jordanokc
Feb 8, 2015 03:59 PM
Snoobly
Dec 11, 2014 11:59 AM
cdetterer
15
Dec 8, 2014 08:46 PM
