Mighty Diesel Visit - Mighty Diesel
2011 Ford 6.7 Tuning by H&S Performance
Old Dec 7, 2010 | 01:44 PM
Mrs. Diesel Pap's Avatar
Site Sponsor - Mighty Diesel
Default 2011 Ford 6.7 Tuning by H&S Performance
H&S just released the tuning for 6.7 Ford
It takes a normal purchase of the Black Maxx or Mini Maxx
and then after you receive it you go onto H&S site and
purchase the 6.7 Ford upgrade for $100.00.
We are working on some DPF delete package deals for the Ford 6.7
They will be on the website in just a few minutes.
2011 Ford 6.7 Tuning by H&S Performance-black-maxx-350-x-390-350-x-390-.jpg 2011 Ford 6.7 Tuning by H&S Performance-mini-maxx.jpg
The Black Maxx race tuner is part of the next generation of diesel downloaders from H&S that offer everything a diesel owner could want, all in one high-tech unit. Exclusive to H&S Performance, the Black Maxx offers the flexibility of shift-on-the-fly tuning, as well as giving you the ability to monitor vital engine statistics at a glance. The full color, high resolution screen allows the user to view up to four parameters at one time. Choose from 20+ engine parameters including boost, transmission temp, intake temp, fuel rail pressure, exhaust gas temps, plus many more (varies depending on application). The Black Maxx comes loaded with 4 power levels that can be changed at any time, on the fly, and is sure to leave the competition in the dust. When you are ready to step up to the next level of performance, step up to the Black Maxx !
Features
* Comes preloaded with DPF Present and DPF Removed tuning
* Allows removal of the DPF system and ALL related sensors (nothing needs to go into the race exhaust)
* Precisely tune engine with HP increases of 0-250HP (dependent on application, see chart below)
* Approximate size: 5" x 3" (2.75" x 2.25" color screen) Black Maxx / Mini Maxx Size Comparison
* Enable / Disable factory "special features". High idle, fogs w/highs, seat belt chimes, daytime running lights, etc. (6.7L Cummins).
* Speedometer recalibration for use of non-stock size tires or gearing
* Automatic safety backdown. Controlled by EGT, Boost, Trans. Temp, and Coolant Temp
* Remove / Adjust top speed limiter
* Allows removal of the entire EGR system including cooler with no trouble codes
* Turn off EGR without removing ANY parts
* Read / Clear Diagnostic Trouble Codes
* Internet updateable w/included SD Memory Card and USB Cable
* Digital gauges to monitor 20+ parameters
* Custom Tunes are FREE to download. Check the downloads section to see whats available for your product.
* Allows for use of aftermarket turbo kits with no trouble codes (6.7L Cummins)
* Transmission tuning included on the 6.4L Powerstroke
* Transmission Tuning Available for the 6.7L Cummins
Old Dec 7, 2010 | 07:38 PM
diesel pap's Avatar
bump
hondardr10
Ford Powerstroke 2011-Up 6.7L
Dec 28, 2014 04:33 PM
Nov 4, 2014 01:30 PM
Oct 14, 2014 08:40 AM
