94 turbo 7.3 no start or starts and dies no restart need help
Old Nov 29, 2010 | 07:01 PM
tkazanecki's Avatar
Default 94 turbo 7.3 no start or starts and dies no restart need help
This truck has 200,000 miles runs great 1 day the next may start right up run for 1 minute or so and dies like key was turned off. Will not start again for a little while 10 minutes or so then does the same thing. Or it may not start at all the first time. There is fuel in the filter every time I check it. I am not really up on the computer controls so dummy terms will be best for me. Any help will be appreciated.
Old Dec 1, 2010 | 09:58 PM
fordornothing's Avatar
it might be the Cam Position Sensor. (CPS) or a failing High Pressure Oil Pump (HPOP). is it a "powerstroke" or just the "turbo diesel"?
Old Dec 2, 2010 | 06:42 AM
tkazanecki's Avatar
Default 94 F250 power stroke
Thanks for the advice the truck is a powerstroke the cam sensor I know where it is the high pressure oil pump coul you tell me more . Is there a test I can do to check cam sensor?
Old Dec 2, 2010 | 12:03 PM
to my knowledge, no. just replace it. there is/ was a recall from ford for it. the HPOP. is at the front of the engine on top. it's in the bottom of the valley. the HPOP isn't a cheap part. on Diesel performance parts and accessories. Diesel injectors, pumps, filters, kits, additive, gauges and apparel.. it's $400.
Old Dec 2, 2010 | 12:52 PM
PSD's Avatar
PSD
Check all of your wire and connections. They tend to melt sometimes. Ive had the IPR wire melt which causes my no start issue. Ive also had a UVCH pigtail melt. Check my no start thread for more info
Old Dec 5, 2010 | 01:53 PM
tkazanecki's Avatar
Default the cam sensor fixed the problem Thank you
If a guy wanted to body lift this truck 94 f250 powerstroke what would you recommend . I am thinking about a 4 inch
Old Dec 5, 2010 | 06:16 PM
do a suspension lift. it looks better. not as gay as a body lift.
Old Dec 5, 2010 | 06:22 PM
99stackedpowerstroke's Avatar
on a body lift you dont want more than 3 inches cause then the body gets to far from the frame and easier ta roll and twist body off cab, go suspension
dshopex4
Chevy/GMC Duramax 01-04 LB7
14
Apr 15, 2015 09:40 PM
