1994 6.5
Old Nov 23, 2010 | 07:54 PM
nftuatn's Avatar
Default 1994 6.5
ok ..my truck starts and runs and idles fine...after about 20 min of driving it will spit and sputter and die...when it starts to do this ..it wont rev up at all..nothing...
then just turn off and restart and runs fine for 5 minutes then off again...
i have replaced 8 injectors all in last week..
white smoke bellows out also when it does this...
and when i break loose the filter element it has a lot of air in it...seems to me its loosing fuel pressure...
am i right thinking that?
Old Nov 24, 2010 | 12:43 AM
TruePerformanceDiesel's Avatar
FormerVendor
Sounds like the lift pump is going out. How many miles on it?
Old Nov 24, 2010 | 07:03 AM
nftuatn's Avatar
has like 300000 on it...also replaced the oil pressure sensor on back of engine
injectors,sensor been replaced..
Old Nov 24, 2010 | 08:23 AM
1994 GMC 6.5's Avatar
have you replaced and relocated ur pmd
Old Nov 26, 2010 | 07:19 PM
angelic0-'s Avatar
PMD, Lift Pump OR WORSE !!! Injector Pump !!!
Dad's truck has the EXACT same symptoms... his IP is shut !
Dieselhead6.5
Oct 6, 2015 09:47 AM
Jake202
Jun 21, 2015 09:42 PM
smokin91rs
Jun 2, 2015 09:18 AM
ssmith.77
Jan 11, 2015 02:03 PM
bdemutis
Nov 28, 2014 08:16 PM
