check engine codes
Old Nov 21, 2010 | 09:14 PM
stevenbrazell's Avatar
Default check engine codes
hey yall,
i work at a lube shop while in college and our scanner broke for check engine lights.
i accidently found if you press the trip/odometer button then turn the ignition to on, the computer checks the gauges and i think diagnoses any codes it has.
i got the following,
2358, aa02, ab02, ac02, ad02, ae02
dont know if those are just useless numbers or actual codes im throwing.
any help would be appreciated.
"After the gauge test is over "C" codes will display in the odometer section. "C" codes are different from "P" trouble codes, "C" codes mostly denote problems in the vehicle electrical system such as headlight circuits (or other circuits) open or shorted, plus instrument cluster and communications errors."
Last edited by stevenbrazell; Nov 21, 2010 at 09:14 PM. Reason: Automerged Doublepost
burndiesel
10
Feb 7, 2023 01:15 AM
gauge1325
May 3, 2015 01:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
24valve4x4
Dec 16, 2014 08:04 PM
Rebel_redneck
Sep 29, 2014 11:05 AM
