Help me with this Duramax belt please. I have a video!
Old Nov 18, 2010 | 10:30 PM
Begle1's Avatar
Default Help me with this Duramax belt please. I have a video!
First of all, the idler pulley between the compressor and the alternator FELL OFF the other day. It was replaced by a guy I wouldn't trust within a mile of a wrench, but he tries.
Is this even a California truck?
Now it's making this horrendous clicking/ grinding noise. It sounds very, very much like it's coming from the tensioner. It goes away entirely if you give it a couple hundred RPM and then comes back when you drop it to low idle.
http://s159.photobucket.com/albums/t130/Begle1/?action=view&current=MOV03073.mp4
Anybody ever hear that before? Tensioner? Or is something routed wrong? Can it just be taken apart and lubed perhaps?
Old Nov 19, 2010 | 07:19 AM
Rttoys's Avatar
The video won't play.
The belt tensioner could be weak or something like the ac compressor could be causing tension on the belt and making the tensioner go ape nuts.
Old Nov 19, 2010 | 09:44 AM
Begle1's Avatar
Come on Photobucket, how the hell does an 8-second-long grainy video of a belt tensioner violate terms of use?
Please see attached video.
I can de-tension the tensioner with a ratchet and spin the pulley on the end; it's spins great. All the rest of the pulleys feel good. I think the noise is coming from the spring-loaded side of the tensioner. If I push down on the tensioner, it stays down...
File Type: zip
Old Nov 19, 2010 | 10:47 AM
BriteWhiteRam's Avatar
maybe try replacing the tensioner?
Old Nov 19, 2010 | 12:59 PM
Rttoys's Avatar
Sounds like the spring side of the tensioner is getting weak. $60 for a new tensioner is good insurance either way. I've had a few Dmax's play hell on tensioners.
Old Nov 19, 2010 | 01:46 PM
Begle1's Avatar
Should it only be $60? The guy working on it says its $200.
Why do they play hell on tensioners? I just don't see how a pulley falling off would wreck a tensioner...Unless it was just the initial slam-bam that did it.
And is that pulley falling off a common problem?
Old Nov 19, 2010 | 03:22 PM
Rttoys's Avatar
According to my wholesale company I use, a Goodyear belt tensioner part # 49278 is $57.49. A regular auto parts should be comparable and Delco might be a tad more, but not $200.
Edit: Gates from O'Reilly $82 List: Search for '38172' | O'Reilly Auto Parts
For some reason, the ac compressor plays hell on the tensioner. Look at the ac lines on the compressor, it has 2 'mufflers' on there. That was to help with the constant vibration, but it still hammers the tensioner.
I've had a few pully problems on my work trucks, but usually it's on vehicles over 200k.
Ironmanqb
Apr 4, 2015 10:27 PM
Feb 24, 2015 04:00 PM
Dec 17, 2014 04:20 PM
duramaxtuner
Dec 10, 2014 01:24 PM
Oct 11, 2014 06:25 AM
