6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
Dually Conversion
Old Nov 18, 2010 | 08:35 AM
tyler111991's Avatar
Default Dually Conversion
Has anyone ever converted a single wheel truck to a dually? What all would i really have to do to do this? thanks in advance, tyler
Old Nov 25, 2010 | 08:56 AM
the warden's Avatar
well all u really need is the dually rims and fenders other than that it is pretty much the same setup
Old Nov 25, 2010 | 10:35 AM
Longhorn's Avatar
No...depending on what make model and year, normally the axles are different length...
Also different wheel studs, sometimes different brake drums...
Normally if you change the studs out to accept duals, you will find your outside dual sticking out further than on a 'real' dually...
Check the axle part numbers for your truck and then a dually in the same year, see if they are the same?
Old Nov 25, 2010 | 11:08 PM
Crazy's Avatar
sw axle are shorter you will need spaces for wheels drums and brakes are bigger on dulley the sw so petty much what londhorn said is right
Old Nov 26, 2010 | 08:10 PM
the warden's Avatar
I stand corrected but just for reference the rims and fenders are all u need for the most part right?
Old Nov 26, 2010 | 09:41 PM
Longhorn's Avatar
Did you read the above posts? Gonna need more than that...
Old Nov 26, 2010 | 11:58 PM
I found a guy locally that has a single cab long bed dually with a blown 454 in it he is selling pretty cheap, would it work if i just used the entire rear end from that truck? im not sure on the year and dont know if its 4x4 or not? thanks
Old Nov 27, 2010 | 12:16 AM
Crazy's Avatar
don't what yr you are talking about but do from dually that from 77 to till 2000 that drums hubs and bearing are the same there may be diff in wheel studs that you have to change
also not sure on the gearing what the ran back the
Old Nov 27, 2010 | 12:25 AM
i think it might be a 94 or 95 but im not sure, im going to look at the truck monday
Old Nov 27, 2010 | 02:54 AM
FastCR's Avatar
there have been variations in the 14 bolt. If the perch width is the same as your truck, you should be good. Also keep in mind chevy spring perches are actually an inch closer (IIRC) on the back than the front. Just measure perch to perch, if they are the same, it will work. Then you should just need wheels, fenders, and a box (maybe?) to run duals.
Also the fronts are different, as you probably know, if you want to run dually front wheels.
