94-98 7.3L Performance Discussion of 94-98 7.3 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
f250 solid front
Old Nov 3, 2010 | 08:10 PM
codyawise's Avatar
Default f250 solid front
i have a 97 f250 with the dumb a$$ independent suspension. some people may like it but as for myself i dont at all. so im wonderin, i know people have done it, how difficult and how expensive would it be to put a solid front axle on my 97 stroker?
Old Nov 4, 2010 | 02:28 AM
cummins bronco's Avatar
its real easy and costs depend, i bought a complete truck for the front end i put in my old powerstroke and actually made money after parting it out, but i have also seen guys asking $1500 + for Dana 60s
it is a direct bolt in, just make sure you get the spring plate and track bar and bracket.
Old Nov 13, 2010 | 05:19 PM
RattleBomb7.3's Avatar
just finished the dana 60 swap a while ago, it's direct bolt in but I had some brake hose issues and had to use F350 brake hoses. I bought mine from a parted out 1992 f350 for $350!!!!! i think 1988 to 1997 solid fronts are all the same.
Old Dec 20, 2010 | 10:11 PM
DaneF's Avatar
Up to 1992 was a kingpin front end so you can go hightsteer. 1993 up went to balljoints.
Old Dec 23, 2010 | 07:34 PM
fordornothing's Avatar
over all the swap is easy. i did it on my 94 f250. eveything ligned up and the only holes i had to drill were for the sway bar. when you find an axle, make sure the tie rods, trac bar, and ball joints ar all good.
shingi
Off Roading
Sep 30, 2015 11:17 AM
natenel1
Oct 26, 2014 03:09 AM
