1and a half inch level or 2 inch??
Old Nov 3, 2010 | 11:09 AM
Dude_57's Avatar
Default 1and a half inch level or 2 inch??
Ok so I have a 2wd truck and I want it look a little better then the stick height of really low I was wondering what would look the best on my truck without wearing anything out fast on the suspension please let me know! Thanks!
Old Nov 3, 2010 | 11:24 AM
Shocker's Avatar
I would suggest going with the 1.5" spacer with shocks. If you go the 2" I believe that you will need UCA to get the correct a clearance and alignment adjustment. Let us know if you need these or if you'd like more info contact us.
Old Nov 3, 2010 | 07:36 PM
Dude_57's Avatar
Hmmm would it look good with a 1 and a half inch front lift??? I kind of want it as high as a 4x4 but maybe not quite that high
Old Nov 4, 2010 | 10:50 AM
Shocker's Avatar
It's hard to say with out seeing the vehicle. You could measure a point on the front of your truck, then with a jack raise the front 1.5-2" and see how it looks. This is the cheap and most cost effective. I'd also try to look at how much clearance and droop your suspension has left at each height. (REMEMBER USE JACK STANDS!!)
