Need help with lift ASAP
Old Nov 2, 2010 | 11:23 AM
02LB7DURAMAX's Avatar
Default Need help with lift ASAP
Hey guys I have an 02 dmax cc/sb and want to put a 4" suspension lift on. I was looking at the tuff country but I don't like the t bars hanging down. Any advice on other lifts or what I can do about the t bars is helpful. I want to run 35 12.50's with 18's, any pics or adivce is greatly appreciated thanks for the help. Btw I am going to be buying the lift and tires hopefully this weekend so thanks for quick responses.
Old Nov 3, 2010 | 10:20 AM
Shocker's Avatar
I would suggest looking into the Cognito 4" Non Torsion Bar Drop Kit. Torsion Bars are in the factory location. The system also includes their Pitman & Idler support kit which is a must have for a lifted truck. If you have any additional questions contact us.
We not only sale parts we install them at our shop so, we can walk you through the install.
Check out this link:
Cognito 4" - 6" Suspension Kit (Non-Torsion Drop) 2001 - 2010 GM 8-Lug (4WD) :: Cognito Motorsports :: Suspension Systems (8-LUG) :: CHEVY/GMC :: Suspensions & Lift Kits :: Suspension :: Shocker Motorsports
Old Nov 3, 2010 | 10:00 PM
Ok thanks for the help I will look into that lift.
Old Nov 3, 2010 | 11:03 PM
FastCR's Avatar
bds makes one too.
Old Nov 4, 2010 | 08:47 AM
Do they make a 4" or just a 6"?
Old Nov 4, 2010 | 10:39 AM
Shocker's Avatar
The BDS kit is 4.5-5" and they make a 7" non torsion bar drop kit. Both systems work well and are a good choice. We have worked with both BDS and Cognito for many years. We usually will see what direction the customer wants to go then we will suggest one direction that we feel is best.
If you have any questions feel free to contact us.
Pat
Old Nov 4, 2010 | 02:09 PM
Ok thanks for the help guys I will look into those lifts.
Old Nov 4, 2010 | 03:49 PM
Shocker's Avatar
No problem were here if you have any suspension/differential questions. Keep us posted on which direction you thinking about.
"Do it right the first time!"
Old Nov 5, 2010 | 07:42 AM
Ok thanks I will keep you posted.
I am still trying to find the best kit but I really like the bds lift, so I think thats the one I will go with. I am going to decide this weekend.
Last edited by 02LB7DURAMAX; Nov 5, 2010 at 07:42 AM. Reason: Automerged Doublepost
Old Nov 7, 2010 | 07:01 PM
bigc45004x4's Avatar
My brother has an RCD on his. But BDS has the best warrenty hands down..
