Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
75w140 for rear end?
Old Oct 30, 2010 | 06:40 AM
anotheraznguy's Avatar
Default 75w140 for rear end?
Hey guys.. just browsing through the oem manual.
for heavy towing duties, it states to run 75w140..
does anyone run this? if i put it in my rear end will i screw things up?
and what is considered heavy towing?
i tow a 6-10k lbs bi monthly. with the remainder of the time the truck is used for parts runs around town and go 150 miles a day to work..
Old Oct 30, 2010 | 08:34 AM
RAW's Avatar
RAW
My work truck is a 2006 F550, and comes in at about 18,000 lbs in what I classify as empty. It has a 9 foot service body, crane, air compressor, blah blah blah. We run 75-140 in the rear end all the time, and have never had any problems. We have 4 of these style of truck, ranging for 2005 to 2007, all weighting about the same, and they perform the same duties.
With the weight your towing, I don't think it is necessary, but won't hurt anything putting it in.
Old Oct 30, 2010 | 09:36 AM
Deezel Stink3r's Avatar
I have a small 99' Cherokee and the manual calls for 75W 140 when towing. So I run 75 W 140 in the rear as demanded. It's doing fine.
Heavy towing is easy to describe.
The extra load stresses the gearing, because the extra load has to be acccelerated too and is added to the gross vehicle weight. The load is put on the gearing of course.
A thinner oil like the75W 90 is pushed aside very easy. A thicker oil compensates heavy loads under heat. look at it like greased bearings. the oil takes the load variations, minimizes friction and takes away the heat.
The second number is the viscosity of the gear oil at 212°. That means 75W 140 has a viscosity of 140 at 212° compared with a viscosity of 90 at 212°.
Old Oct 31, 2010 | 03:05 AM
awesome.. thanks for easing my mind guys..
Old Nov 1, 2010 | 08:11 AM
Heath's Avatar
Authorized Amsoil Dealer
It won't hurt anything. The only thing it could do is decrease mileage a bit, but even if it does, it won't be much.
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
Machinist
Jun 23, 2015 06:57 AM
Mar 27, 2015 07:20 PM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
