no hot air from heater
Old Oct 27, 2010 | 06:07 PM
jasonshort's Avatar
Default no hot air from heater
I started my 04 ford 6.0 this morning to warm it up. it ran for about 20 mins but when i got in it was blowing cold air. The air didn't get warm untill i pressed the go pedel. When i let off the pedel and the truck is just idling it goes cold again. Does anyone know whats going on?
Old Oct 27, 2010 | 08:35 PM
FastCR's Avatar
is it full of coolant?
Old Oct 27, 2010 | 11:18 PM
jasonshort's Avatar
Yep it is full of coolant
Old Oct 28, 2010 | 07:00 PM
cummins bronco's Avatar
thermostat may be stuck open, is the temp guage coming up?
Old Oct 29, 2010 | 08:32 AM
Jagsdiesel's Avatar
Diesel Bombers Sponsor- Jags Diesel
A couple of issue possible. First weak water pump. When rpm's go up it pushes more coolant. Second blown head gasket pressureizing cooling system. Same thing at idle the air pockets find the heater core, as the rpm's come up the water pump can push the coolant into the heater core and the air pockets out. Third possible heater core starting to clogg.
junkboxcummins
Jun 17, 2015 10:39 AM
carid
Diesel Bombers Sponsors
May 27, 2015 07:01 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
sjcdep08
Nov 12, 2014 07:05 PM
