6.2L & 6.5L Performance Discussion of Chevy and GMC Trucks with 6.2L and 6.5L Diesel Engines Related to Performance and Longevity
92 and 93 6.5 diesel owners
Old Oct 25, 2010 | 05:18 PM
tyler111991's Avatar
Default 92 and 93 6.5 diesel owners
Has anyone used the mechanical wastegate that Heathdiesel.com has?
Its $109.00 i think. it says that it makes a pretty good improvement. I dont really think i could figure out how to make a wastegate controller that works properly so im leaning more toward this one haha
Old Oct 25, 2010 | 05:42 PM
Woody35's Avatar
it will work good for you. i see you have a boost gauge and a turned up ip so just keep under 15 psi and your power and mpgs should increase
Old Oct 25, 2010 | 08:54 PM
Crazy's Avatar
Here so info on making your and save lot money
Here's the adj controller i fabbed up. Hope it helps ya'll.
First pic is the original with the "lip" ground off and pop'd apart with the new 1/4" rod i bent. Second is the thing attached, third is the adj end. Total cost $5.97. I measured the length between the inside of the lever hole to the step on the original rod. Then when i installed it, made the length the same. 10 5/8" on the GM-3. After i get the truck back together, i'll use the pyro & boost gauges to set the boost and turn up the 4911 if needed.
Attached Thumbnails 92 and 93 6.5 diesel owners-1.jpg   92 and 93 6.5 diesel owners-2.jpg   92 and 93 6.5 diesel owners-3.jpg
Old Oct 25, 2010 | 09:56 PM
thanks that looks really simple! I might have to try that tomorrow
Old Oct 25, 2010 | 10:39 PM
Crazy's Avatar
Let me know how make out
