7.3 Oil leak..
Old Oct 13, 2010 | 10:45 AM
2000stroker's Avatar
Default 7.3 Oil leak..
my stock 2000 7.3 leaks a little oil not from the bottom but i find oil on the top of the motor at the rear in the valley...trying to figure out where the hell its coming from but not sure..any one have any suggestions on what it could be or even where i should begin to start looking????
Old Oct 13, 2010 | 11:52 AM
CSIPSD's Avatar
Turbo Pedistal, Turbo, Exhaust Back Pressure Valve, HPO fittings, HPOP, Could also be fuel from the drain valves... Clean up the valley really good and watch it for a few days.
Old Oct 13, 2010 | 03:08 PM
Lange503's Avatar
yeah what he said, i'd lean more toward the turbo pedistal but you never know until you dig into it
Old Dec 10, 2010 | 07:31 PM
chucks 7.3 f-350's Avatar
check your hi pressure oil pump and resavoir and lines going to heads
Old Dec 17, 2010 | 11:04 PM
DucatiBrandon's Avatar
I just park in the dirt now at home. I think that's all these do is leak oil.
Old Dec 17, 2010 | 11:20 PM
99stackedpowerstroke's Avatar
i would lean towards the hpop lines going to the heads, it could be leaking there and as your driving the oil is running to the rear of the motor,
Old Dec 17, 2010 | 11:23 PM
prison's Avatar
would that be because you can't fix them? if you cant fix it sell it and get somethin ya can fix. like a bicycle
Old Dec 20, 2010 | 12:48 AM
strokinf350's Avatar
true that prison!!
Old Dec 20, 2010 | 12:58 AM
prison's Avatar
My 93 leaked oil. lifted the engine in my driveway. replaced the oil pan. done. my 85 doesn't leak one drop of ANY liquid. it was leaking PS fluid which was a seal which i fixed in my driveway until 5 in the morning. I do all my work and take pride in my truck. when you do this your truck lasts. I've been around a lot of powerstrokes and they're owned by people who take pride in them. None of theirs leak. One kid i go to school with likes to try to blow smoke and beat on his truck. guess what it leaks a lot of oil
Old Dec 20, 2010 | 01:43 AM
Rustin's Avatar
I agee with cleaning the valley and watching to see where it is coming from.
