Bad smoking on vacation, need advice
Old Oct 9, 2010 | 07:02 PM
SteveE's Avatar
Default Bad smoking on vacation, need advice
Getting a lot of blue gray smoke at idle (people staring). Seems to go away with some revs. I am 3000 miles from home. I have been using diesel kleen. No misfire, good gas MPG, no check engine light. Is it OK drive it home like this?
Old Oct 9, 2010 | 07:51 PM
smokeeaterlb7's Avatar
Bad Injectors...
Old Oct 9, 2010 | 08:02 PM
bobcat67's Avatar
gonna need to know a bit more on the truck to say that for sure, but it sure sounds like injectors to me, check the oil level and see if it's a little more full than it should be, cause that is also another sign
Old Oct 9, 2010 | 10:43 PM
SteveE's Avatar
Ok, I'm thinking it's the injectors also. The question is can I drive it 2000 some miles home without a problem or do I need to get it fixed first. It a 2003 Duramax. The injectors were replaced at 40k, and now the truck has 100k.
Old Oct 9, 2010 | 11:09 PM
FastCR's Avatar
I'd get it checked out. I'd worry a cylinder could heat way up. Where are you now? Maybe someone can recommend a good shop.
Old Oct 10, 2010 | 12:03 AM
SteveE's Avatar
Carmel, CA
Old Oct 10, 2010 | 01:00 AM
FastCR's Avatar
I could get recommendation for 250 miles south and maybe 250 miles north, but hopefully someone can chime in about somewhere closer. Where are you headed after there?
Old Oct 10, 2010 | 01:48 AM
biged681985's Avatar
id put money on it is ur injectors. i wouldnt recomend driving it 2000 miles.
Old Oct 10, 2010 | 10:35 AM
SteveE's Avatar
I 15 thru Vegas then I 70 thru Colorado then to Mpls. MN. Thanks for the replys
Old Oct 10, 2010 | 11:22 AM
skinnysfd's Avatar
To bad u arent closer to me already you will prolly go right by me on your way to minneapolis. if you get closer and need some help let me know. there is a pretty good shop in sioux city to get injectors from. just keep us updated
