Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
install a new stereo
Old Oct 8, 2010 | 09:22 PM
darnit114's Avatar
Default install a new stereo
hello all, i have a 94 12 valve with which i just started doing some work on. I am sort of turning it into a welding/mechanics vehicle and its turning out pretty decent. The inside of the cab is torn up a bit from years of abuse and that is slowly coming back together as well. I was in the process of installing a new stereo and ran into a prob. The truck has the infinty sound system in it and the deck is a kenwood, just a regular cd,ipod,amfm thing with the normal stereo hookups. I got it all hooked up and got all the wires spliced good and tight and nothing loose. When i turned the key on there was only sound coming from the front left speaker and nowhere else. It seems as though i experienced this same problem a time before and took it to a stereo shop to get corrected, however i dont exaclty remeber what they told me they did to fix it. I do remember something about a wire that had to be spliced back into the harness or something being that it has the infinty speaker system. If anybody knows about this could you please help. I have searched inside the dash and am not missing any wires and it is grounded to the ground coming out of the pickups radio harness.
Old Oct 8, 2010 | 10:18 PM
RAW's Avatar
RAW
The Infinity system has another relay to power the amps in the doors. There is a light green wire behind the deck area than needs to be hooked up to your blue remote wire. I think this is the problem you are experiencing.
Old Oct 12, 2010 | 09:02 AM
darnit114's Avatar
well that is what i had done i thought, after your suggestion i got back into it and got to looking and my remote wire from the deck was not putting any power out, so i found a const. p wire that was and connected it in that place. Now she works good thanks i appreciate it.
450r racer
8
Dec 21, 2015 06:42 PM
Apr 29, 2015 08:20 AM
Gman30
Dec 27, 2014 12:46 PM
Cody Cain
Dec 21, 2014 06:50 PM
Loghomeman
Oct 25, 2014 08:18 PM
