06 dodge
Old Oct 3, 2010 | 07:39 AM
dodgethat's Avatar
Arrow 06 dodge
my truck has been running ruff at idel and the other day I pushed the pedel and it got hot I mean egt got hot by the time I hit 80 mph the engine light came on plug in my smary and it said map sensor low voltage if it is my airflow sensor where is it located on my truck I have never cleaned it my truck has 38000.00 miles code was p0107 also is it still drive able or will it just quit on me
Old Oct 3, 2010 | 10:51 AM
cummin_un_glued's Avatar
FormerVendor
the map sensor is in the intake plate between the 3 and 4 injector lines it is held in place with 2 t15 torx screws.....also have you been noticing any smoke other then the smoke from the smarty...like any grey smoke at idle when its running rough?...noticed any kind of rattle to the engine under throttle?
Old Oct 3, 2010 | 05:32 PM
dodgethat's Avatar
yes to the rattle I have not seen smoke but I have not looked for it
Old Oct 3, 2010 | 09:25 PM
FormerVendor
i dont really think that the rough idle and the high egts and map sensor are going to be related...i mean i guess if the map is showin like 41psi (top of the range of the sensor) and the ecm was fueling it for that much boost it could....on the 06 that i had i got a map code a couple times i would just clear it and it wouldnt come back for a few months tho....sounds to me like you got a couple injectors cracked and they are over fueling those cylinders...that will cause a rough idle untill the engine temp comes up to burn the extra fuel then it will also cause the rattle when your on the throttle
Old Oct 3, 2010 | 09:30 PM
wildbill's Avatar
If your throwing a MAP/AIT sensor code, the truck would go into limp mode. Post the code here so we can help you further.
Old Oct 5, 2010 | 09:59 PM
dodgethat's Avatar
not sure the code is clear and I cleaned the map seems to run smooth it just gives me the noids that something is wrong but ok for now the truck will still temp out on the egt if I stomp on it and hold it down the egts flashes at about 80-85 from 60 mph not sure if it was always like this I never held it down until I had a problem I have my smarty set at # 5 with 5 in exhaust from turbo back
May 7, 2015 02:50 PM
Dec 29, 2014 10:20 AM
Dec 12, 2014 12:30 PM
Nov 16, 2014 06:10 PM
Nov 3, 2014 08:10 AM
