fuel pump problems on my 2001 f350
Old Sep 26, 2010 | 11:17 PM
deegan24's Avatar
Default fuel pump problems on my 2001 f350
does anyone know what the symptoms are on the low pressure fuel pump if it is starting to go bad?
Old Sep 27, 2010 | 08:34 AM
badluckman's Avatar
Default fuel pump
well u should check the presure, or keep a eye on the fuel level in the bowl, and if its not pumping fast enough or the presure is low it could stall, hard starts, could miss alittle a guess,im not a expert or anything but if it gets down to it missing or not supplying enough fuel to injectors that is very bad for the fuel injectors,it could damage them,the low presure pump only supplys the fuel from tank to injectors, the injectors pressurize the fuel further to spray it into the cylinders. good luck and maybe post your symtom to,maybe someone will have a better idea for you... good luck
Old Sep 27, 2010 | 11:02 AM
CSIPSD's Avatar
What are your issues?
Most times with a bad fuel pump you will get low power, and stalling. You can also hear the injectors running out of fuel...
Cavnar
Sep 9, 2015 07:18 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
moneypitk5
Feb 12, 2015 11:01 AM
