Passenger window stuck.
Old Sep 25, 2010 | 12:20 PM
DuramaxDiesel02's Avatar
Default Passenger window stuck.
So this is the second time this has happened since I had this truck.
Same window as well. I dont want to pay another $300 for a fix.
Anyone no how to remove the inside door plastic and handle to access the motor? Thanks
Sent from my Droid
Old Sep 26, 2010 | 08:53 PM
acdc's Avatar
pry with screw driver or panel puller around door handle plastic insert. rotate and pull handle to remove. take the panel puller from upper inner (below window opening) prying down, across bottom of panel, then up to top of panel on outer side. with plastic inserts out of there holes, lift up on panel and removing upper hanger from inner door frame. u may have to peel plastic away from inner frame to access window motor.
Old Sep 28, 2010 | 05:40 PM
Default Re: Passenger window stuck.
Thank you for that. Ill have to try that soon.
Old Sep 30, 2010 | 10:53 AM
dmaxtothemax's Avatar
I know in my gasser it made more since to just change the entire assembly out... It takes longer to dis-assemble door panel than to change the assembly... hope this helps
bosse777
Sep 28, 2015 05:38 AM
carid
Diesel Bombers Sponsors
Aug 13, 2015 05:49 AM
Bottlerocket12v
Mar 12, 2015 09:10 PM
Cummins_Power_13
Feb 4, 2015 09:55 AM
Dec 2, 2014 03:10 AM
